Identify early frame
Re: Identify early frame
2 3/4 HP and C8
Components Dion
Components Dion
The engine is in very good condition so what can you do with it.
You could put in the 2000 hours and make the tricycle viewtopic.php?t=410&hilit=1898
Or put it in a pre 1928 frame viewtopic.php?t=14079
You need to alter the drive to the otherside.
Or use it as a doorstopper .
The fact that it says Components Dion it could be a farmhouse drive component from day one (C8 Components nr.8), the Dion part was only the patent thing, there is no Dion made engine looking like this.
I need a photo from the other driveside to see if it had a gearbox, if it has than it could even be a Fleet tricycle (if they where already using that name in 1901).
the other driveside is visible on the first picture I posted.
The magneto sprocket is in the way of seeing 4 bolts under the crank that's where the 2 gearbox was bolted.
- Karol Burger
a beautiful piece.
- Karol Burger
a beautiful piece.
This engine is forsale at Yesterdays, as you can see it's differend.
I think it's 1902-1903 of a tricycle with the engine behind the axel like the one in the Beaulieu museum but you can put it in a 2 wheelerframe.
https://www.yesterdays.nl/product/brits ... 1900-2809/
One can always mill off those ears front & back
Users browsing this forum: Google [Bot], Laurenceb and 1 guest
