Page 2 of 2
Re: Rear wheel alignment/chain rubbing primary chaincase
Posted: Wed Nov 16, 2022 5:46 pm
by Simon.Gardiner
Adam - as an aside, if that's your 'proper' brake in your pic it shouldn't be bent to go around the frame like that....
Posted: Wed Nov 16, 2022 6:45 pm
by Adz.F
Simon, do you mean the brake rod or the steel stay? The rod is just one that came with the bike bits where as the stay came from drags. I have a brake arm coming this week so will be able to assemble the brake shoes etc in the hub. I did wonder if it was the correct rod as in the parts book it shows it being straight.
Adam
Posted: Wed Nov 16, 2022 6:56 pm
by Simon.Gardiner
The rod! The brake rods are straight, with the proper brake arm you should be able to get it lined up correctly.
Posted: Wed Nov 16, 2022 7:02 pm
by Adz.F
Awesome, thank you
![😊](//twemoji.maxcdn.com/2/svg/1f60a.svg)
