Hi All,
I wonder if someone on here could help me with a query I have regarding painting my 1938 NG petrol tank correctly?
It's a chrome plated tank and I need to add the two side panels as well as the top one all in black lined in gold.
I am mostly concerned about the shape and size of the top panel. I have seen variations on the website photos and not quite sure what is correct. I have seen some with a top solid panel going right down to the seat end of the tank and I have also seen other top panels divided in two in a sort of inverted Vee starting at the instrument panel and spreading out to the two lower tank extremities.
What is correct?
Also I have seen some tank instrument panels finished in chrome plate while others painted in the main tank panel colours.
Again which is correct please.
Many thanks,
Albert Pisani
Malta
1938 NG tank pattern & finish of instrument panel
Re: 1938 NG tank pattern & finish of instrument panel
As you are an AOMCC member, I have sent you copies of the details you need, taken from the AOMCC archives, in a private message.
Paul
Paul
Many thanks Paul much obliged.
Albert
Albert
