Question about Lucas H52 Headlamp switch
Pictures 3 what does F C H L mean og what functions do they have
Pictures 1 and 2
shouldnt there be connection where i have marked the red in the picture, from my point off view it looks like something has broken off, i have searched they internet for a pictures too compares against.
Kind Regards
Søren
Denmark
Lucas H52 Headlamp
Lucas H52 Headlamp
Last edited by SørenMortensen on Mon Mar 04, 2024 7:47 am, edited 2 times in total.
Re: Lucas H52 Headlamp
26'C, 27'C,28'C,31'MF, 38' RH, 43' W/NG
- Karol Burger
wiring diagram that we offer for download and sale
https://www.arielklub.sk/magazin-schema ... -h-52.html
https://www.arielklub.sk/inzerat-23316- ... -Lucas-H52
i forgot the pictures in my first post, i got the wiring diagram i just need to understand the function of the switch to understand the diagram
The 1st one is OFF, then Charge, High and Low. The charging system is a bit tricky and this is one of the few areas that I would not bother with the original technology unless you you really want to. I convert the 3 brush dynamo to 2 brush, use a modern electronic regulator and rewire the switch to work more like a 1950's one. None of the modifications are visible and you have enough to worry about on an old bike without adding manual battery charging to the tasks.
When the switch is mounted with the screws does it not earth that end of the resistor wire to the frame earth to control the charge rate.
