Leader Indicator Switch Lock Nut
JeffL
Post by JeffL »
My Leader has the Lucas 31823 indicator switch on it. Unfortunately, the lock nut to secure it into the bracket on the handlebars is missing.
Does anyone know what thread that nut should be?
Many thanks
Jeff
rogerlee
Re: Leader Indicator Switch Lock Nut
Post by rogerlee »
Hi Jeffl The standard lock nut is 9/16 " diam.26 tpi 0.709" across flats,0.100" wide,Its a bsb standard brass rate nut.Hoping this helps flatland Roger
JeffL
Post by JeffL »
Brilliant! I'll get one ordered. It will be a lot better than the cable ties holding it together at present.
Thank you for the help Roger.
Much appreciated.
Jeff
Users browsing this forum: No registered users and 32 guests
