oil pump ball bearings
Hi All, what size are the ball bearings in the oil pump on a 39VH are they 7/32" or 1/4 " thanks regards Clive.
Re: oil pump ball bearings
They are 7/32", if using new balls check the seating is good, no raised lip present, and tap/lap seat
Thanks Pete for the reply have to look for two 7/32" balls in the garage in my ball bearing tub thanks again Clive.
If you don't find any, I have a few new ones spare, for the cost of a postage stamp.
If the balls go POP they are sealing alright. I don't think belting them onto the seat would do much. It's quite wide. A careful touch with a ball ended mill might true it up. Worn out of shape balls are totally unreliable as far as consistent seating is concerned. Nev
Thanks Pete, I found a couple of bearings in my cycle parts, Thanks anyway Clive.
Users browsing this forum: Ahrefs [Bot] and 3 guests
