Could this be a brass 500 head?
adrie.degraaff
Post by adrie.degraaff »
Re: Could this be a brass 500 head?
Pretty certain it is metal not bronze, it looks a bit yellow because of the light. Anyway it is for a KH according to the description and has good valve seats (not)
mark.prizeman
Post by mark.prizeman »
Chocolate?
Post by will_curry »
It's got to be cast iron. The bronze colour is applied to the carburetter studs as
well - they're steel.
If you wanted to use the head you'd have to strip that powder coating off, it's
almost perfect at keeping the heat in.
Post by Julian Murphy »
Blasting media lodged alongside the valve guide in picture 5.
Every area not powder coated has that strange 'bronze' colour.
Must be a trick of the light or flash used by the photographer.
Post by JohnnyBeckett »
hi the powder coating will not last long once it gets hot a few times and it is not brass
it's sold £103.11 :o
