'39 Sq4 side stand retaing clip wanted
RayBlack
Post by RayBlack »
Hello
I need a retaining clip for a '39 4G Sq4 side stand. Part number 2462-33. They do not appear to be available from Draganfly, and are not listed on the club's Sq4 spares list. Anybody got one sitting around they want to get rid of?
Thanks. Ray
Re: '39 Sq4 side stand retaing clip wanted
Post by JohnnyBeckett »
hi Ray if you have no luck with the forum, try looking on Ebay you may find one
I'd attempt to make one. Alan Moore did some very good posts on making W/NG fields stand springs which would show you what to do.
RayBlack
Post by RayBlack »
Thanks for the reply Johnny and Simon. I have not had any luck with Ebay (does anyone know how to filter out all the Little Mermaid paraphernalia when searching Ariel parts?). I am expecting I will have to fabricate the spring clip. Fortunately I was a metalworker in a past life.
Ray
The fun bit is getting the temper right - I had two goes at that with the stand springs. The side stand clip might be easier (as it's a bit smaller) but I found controlling the temperature across the whole spring simultaneously quite difficult. I've used a domestic oven for things like knife blades and other cutting tools, but the tempering temperature for a spring is obviously much higher.
there is some sort of side stand on my SQ4 /1939. I'll take a photo for you. If it's the right one you need, we can make a vikres for the missing part.
this is what i have on my 1939 SQ4. I don't know if this is the part you need. :roll:
RayBlack
Post by RayBlack »
Hi Karol. Thanks for the reply. The original factory side stand fits on the right side of the front engine plate and folds back parallel to the lower frame rail where it is held in place by a spring clip retainer (the bit I need). There is a photo of the clip on the main chat forum, but I'm not sure how to get it here...
Ray
john.davies
Post by john.davies »
This is the clip that Ray means
Karol's side stand looks like the modern Royal Enfield stand that you can by off Ebay and adapt to fit, a number of other people on this forum have done this. Details here.
viewtopic.php?p=92552#p92552
Image 1931 Ariel VB31, 1935 Triumph 5/3 project, 1946 Ariel Square 4, 1952 Norton Model 7, 1953 BSA A10 Super Flash, 1954 Ariel VH
RayBlack
Post by RayBlack »
Thank you for posting the photo and for the information John.
Ray
