Good day,
May I ask what is the correct quantity of lubricant to go into the gearbox?
I cannot find this information anywhere in the instruction manuals.
I'm using Penrite semi-fluid grease.
Thanks
John
KH500 Gearbox
Re: KH500 Gearbox
hi, it will have a level plug i would fill it up till comes the level plug hole
Re: KH500 Gearbox
Re: KH500 Gearbox
If you are using a semi fluid grease I assume the gearbox is a C or BA Burman. Burman's say about 1/3 full but not to worry if you overfill as it ooze out of the box until it reached the correct level. I usually put a whole tin of this in https://draganfly.co.uk/shop/83795/gear ... 11/#OI-GRB
Re: KH500 Gearbox
Thank you Gentlemen.
I have 600g so I will put that in.
John
John
Re: KH500 Gearbox
IF you have enough in it should be churning when the bike is run in gear on the stand, visible through the filler on a BAP. Nev
