1930 LF
JohnLay
Re: 1930 LF
Post by JohnLay »
I fitted 2.75/300 x 19 as that was already fitted. An Avon "speed-master" front (which I had to hand) and a traditional block tread on the rear.
Note: The LF is fitted with WM1 rims for which a 300 size tyre is about the largest you should fit.
Talking of which I took the machine to a local Boxing-day meet and found that the rear tyre had gone "flat". Pumped it back up and it's still up now. Not quite sure what the problem is, but will need to keep an eye on it. Ordered a new inner tube to be on the safe side
Will.H
Re: 1930 LF
Post by Will.H »
Thanks John, is the block style tread rear of the same size?
JohnLay
Re: 1930 LF
Post by JohnLay »
Yes it is. Good luck with the prospective purchase, what year is it?
Will.H
Re: 1930 LF
Post by Will.H »
JohnLay wrote: Sun Dec 31, 2023 8:17 pm Thanks John, is the block style tread rear of the same size?
Thanks John, appreciate the info.
It’s a 1930, and apparently the tyres are a bit old so I’d want to put new on before using it really. It’ll be my first foray into classic motorcycle ownership, given that all the bikes I currently own are 00’s onwards! So some new stuff to learn.
ken-drink
Re: 1930 LF
Post by ken-drink »
in the pic of the boxing day meet above my fieldmaster is next to John's LF 250
JohnLay
Re: 1930 LF
Post by JohnLay »
As acquired the bike was fitted with Lucas bulb horn that I did not much care for (thought it was rather oversize) more to the point it didn't work very well anyway. Ordered a 6v electric horn and push button before Christmas, the horn turned up quite quickly was fitted and wired up, but the push button somewhat later. In fact today (6 Jan) fitted the button straight-a-way before it got lost. Toot - Toot.
JohnLay
Re: 1930 LF
Post by JohnLay »
Two Johns, same bike. Faversham 1983 40 years apart Stafford 2023
First photo acknowledgments Faversham News
dave.owen
Re: 1930 LF
Post by dave.owen »
John , I attended the same boxing meet on my sq4
JohnLay
Re: 1930 LF
Post by JohnLay »
The Ariel had been unused for some years and as a result the fuel in the taps had turned into something akin to varnish. The taps themselves had to be drilled out but the gauze filters on the top of the taps remain completely impervious to petrol. Scrubbing with a stiff brush with fresh petrol hasn't improved things. Anyone any bright ideas how to get them clean?
Re: 1930 LF
aceton ? (nail polish remover)
