petrol tank cap washer
Re: petrol tank cap washer
I've got viton discs in two of mine. They've been fine for years.
There's no high pressure surface movement with that cap design if you use the Knob (adjust it) in the centre as it's meant to work. It's the thing that applies the pressure. Nev
- Brian_Walker
Managed to get hold of some rubberised cork gasket material, works very well and does not shrink on drying out. I also used to stop my monobloc carby bowl leaking. Attached is a PDF of typical sizes and properties of this material.
1951-52 VCH under restoration
I use thin (about .045") leather salvaged from the back of a scrapped armchair. It was still on my '56 FH when I sold it after years of service.
