All this with the brake peddle is a bit of side issue as only wanted to take it off so I could remove the primary drive cover. But something would have had to be done sooner later, so why not now.
Not that drilling and tapping was that easy as whatever it was made of was more that just bit on the hard side.
There was just enough of the original thread left to get slim nut on and while I was about it I drilled and tapped the end of the support for a grease nipple.1930 LF
Re: 1930 LF
Spent some time on the magneto, new HT pick-up brush, remove the points assembly, cleaned the points, make sure the little carbon brush was free in it's holder and cleaned the track it runs on. After all of this I was reworded by a spark, not a very good , but a spark none the less. I had previously cleaned out the carburettor so with a little petrol in the float chamber I gave it kick. Nothing much happened until I realized that on this machine advance was "tight wire" after which it started. Didn't run for very long of course, but long enough to inspire me to press. on.
Re: 1930 LF
A look in the oil tank showed a considerable lack of any, and wondering where it had all gone I removed the sump plate expecting that's where it might be. But surprisingly nothing came out. That wasn't the only thing missing, should there not be a gauze filter here?
While the plate was I decided that I would fit a drain plug, nothing more that drilling a hole and brazing a ⅜" nut on and screwing in a suitable set-screw with a fibre washer.
Re: 1930 LF
Yes there should be a gauze to stop bricks from circulating with the oil.
Re: 1930 LF
Spent the day doing one of my least favourite tasks, tyre changing. Both tyres were of the "Block Tread" pattern with the rear being just about at the end of it's useful life. The front was somewhat better and maybe could have done a turn on the rear, but as I had a Avon Speed master front to hand and I had also ordered a new rear, both front and rear were changed.
The original rear lower, the original front, upper and the new rear centre.
An earlier photo of the machine taken 1983 showed that which seamed to be same tyre fitted even then, time for new I think.
Re: 1930 LF
Not a lot of progress of late as a number of things ordered in some cases of more than two weeks ago have so far failed to arrive. One thing that did arrive was a 19 tooth plate-wheel, not really ready for for it, but might as well make a start.
Using an old sprocket given to me by an Ariel forum member (thank you Mr. Coleman) both the plate-wheel and sprocket were drilled and taped as required and then screwed together. The old sprocket acting a guide to form the splines on the new. No doubt it will need a little more "fettling" when I come to fit it on the gearbox output shaft. But I will worry about that when I get that far. In the meantime it was just something to be getting on with.
Re: 1930 LF
The brass mesh ordered some time ago turned up at last.
Here is my effort at fabricating a replacement oil gauze filter, not possibly as elegant as the original but no one is going to see it and I don't have any reason to think it won't work just as well. As Rroger Gwynn says it should "stop bricks circulating in the oil".
