DVR2 regulator question
General electrical problems
bevanclark
Post by bevanclark »
Hi folks, I am going to swap out my old MCR2 as it doesn't seen to be behaving itself despite my best efforts.
See photo for what I was going to do.
My question is: is it ok to fit a DVR2 inside the old cover, or does it need a decent cooling air flow ?
Thanks, Bevan
ian williams
Re: DVR2 regulator question
Post by ian williams »
my voltage regulator is fixed to a bracket onto the original mcr2 base and is "hidden" inside it , works just fine and the metalwork of the case provides a decent heatsink i expect .
ian
Post by JohnnyBeckett »
hi Ian, my one is fix inside the old regulator box as well, and my regulator is in the toolbox on my NH and if it is very hot weather i take cover off the regulator but i have had NO problems with it getting hot :D :D
garycullen
Post by garycullen »
Hi Bevan,
Sorry I have only just seen this post.
I mounted my DVR2 inside the old case but retained the original base.
I also mounted it upside down compared to your picture.
The bolt on the top provides a strong mounting point as well as a heat sink into the base.
I drilled the appropriate hole in the old base of course.
I wired it up to the normal FADE connections so it all looks standard when buttoned up.
Gary
Gary Cullen
Forrest Hill
Auckland
Antipodes
1946 VB600 rigid Tele
1933 Austin 10
