hi does anyone know if you can buy the skrew top grease cup that fits 1938 square four distributor im in need of 2
thanks rod
1938 square four grease cup
Re: 1938 square four grease cup
Hi Rod, try this guy https://www.distributordoctor.com/
tried them but i havent recieved a reply
- john.davies
I used a 1/8 BSP brass grease cup like in the links below and and made an adapter to fit the hole. The adapter had the nose on to hold in the rotor shaft as per the original grease cup had as shown in picture.
https://www.myford.co.uk/acatalog/BRASS ... -1869.html or https://www.ebay.co.uk/itm/292062863158
1931 Ariel VB31, 1935 Triumph 5/3 project, 1946 Ariel Square 4, 1952 Norton Model 7, 1953 BSA A10 Super Flash, 1954 Ariel VH
thanks i have ordered two thanks
