The rear sprocket on my LF is badly worn-out. Need a serviceable or even another bad one to use as a pattern. As they bolt on it should not be too much of a trial to make another from a plate sprocket as I have done that before. Thanks
Rear chain sprocket wanted for 1930 LF
Re: Rear chain sprocket wanted for 1930 LF
John Lay,
youv'e got a different way of uploading pictures, PostImage ?
or did I miss a development ?
I dont go or am on just any media other than a few fora.
anyway, would you please upload pictures via the function at the bottom of each new reply ?
- JohnLay
Got the old sprocket off and it is indeed a separate item. So making another from a "plate sprocket just got a lot simpler.
hi john i use B&C express sprockets to make all my standard or custom sprockets it saves a lot of time messing about making one there is a post in suppliers on this forum
- JohnLay
Bought a "plate wheel" Sprocket and machined up a replacement (see Ariel Talk) so not needed any more thanks.
