VH 1953... nearly finished
Heiko.Hecht
Post by Heiko.Hecht »
Hello,
here is my VH 1953. Nearly finished. Only a few bits and bobs. I hope... fingers crossed.
And also a Model 50 is still in my Garage.
Cheers Heiko
Re: VH 1953... nearly finished
I think you deserve the generous measure, good job.
Post by JohnnyBeckett »
hi i looks like you have done a very nice rebuild if goes as good as it looks you will a very good Ariel enjoy it :) 8-)
klaus gerhard
Post by klaus gerhard »
Hallo Heiko,
deine 53er sieht toll aus. Jetzt kannst Du damit zum Weihnachtstreffen in Amberg kommen.. ;)
Viele Grüße
Klaus
Heiko.Hecht
Good morning,
thanks for the congratulations…
Wann ist das denn Klaus?… Bin ja ehrlich, das ist mir zu kalt. :shock: ;)
Heiko.Hecht
Re: VH 1953... question
Hello,
After I removed the front wheel to replace the tyre, I was a little surprised that the fork rebounded so much. Is this correct or is there a problem on the horizon for me?
Regards Heiko
I think you may have the 1946-53 short upper bushes and the later, long stanchions. The only problem will be slightly faster rate of wear.
Wenn du mit einem Ariel zum Weihnachtsessen fährst, bist du dort das einzige Fahrrad, es sei denn, Klaus fährt mit seinem Ariel???
Heiko.Hecht
Thanks for the input Roger. Have to be done somehow next year.
Amberg in the wintertime is a little bit to far and cold with a bike…. About 500km one way.
