1930 LF
- JohnLay
1930 LF
Just acquired a 1930 Ariel model LF, Not a machine I have had any experience with.
Mostly all there, doesn't have a speedo (there is a hole in the tank for it complete with a chrome blanking plate) or the drive for it which I believe comes off of the gearbox. Also missing is the HT pick-up from the magneto, it's a Lucas type but not sure which model as it is not possible to see the markings while it is clamped into position.
Any information would be useful.
The machine was previously in the John Hobbs collection which was sold at Bonham's auction this last weekend. John it seems was a large collector of such machines there being a number of other LF's plus a big selection of frames, forks, tanks engines e.c.t in the same sale.
Re: 1930 LF
I was also at the auction and bought a box of '29 LF hubs! There was a lot of LF bits and bobs
Re: 1930 LF
That's an interesting magneto arrangement.
Bertie, I have need of a timing cover and the sprockets for the magneto drive . . .
. . . I don't suppose you've any spares?
Re: 1930 LF
This is how the pick up looks like, sold out atm with Vintage Replica but these must be available somewere in the UK
https://www.vintage-replica.com/204--re ... p-lucas-2/
- JohnLay
Re: 1930 LF
Hi Bertie, my rear sprocket is just about worn out, did you get any of those with your hubs? Not really that hard to make another but just easier if someone has got one.
- Bob.Murphy
Re: 1930 LF
Bertie, does this mean that the Tiger Cup rear wheel is being replaced ?
Need another wheel spindle ? .
Re: 1930 LF
Hi Bob, sadly yes it does mean the tiger cub wheel and spindle are being replaced, fingers crossed I won't need a new spindle as the rear hubs are complete with spindles.
John Lay - there are two rear sprockets in the box of bits i bought, so potentially a spare, i've not had a good look at them to see how good either are.
Will Curry, I might have a spare timing cover, if i do its buried in my garage somewhere, sprockets for the magneto drive sadly not.
- JohnLay
Re: 1930 LF
Thank you Vincent.vanGinneke , sadly out of stock
Bertie, I will send you a PM
Re: 1930 LF
This was owned by John Hobbs from at least 1977 and possibly 1969. It is first recorded with engine L 1180, a 1929 LB in 1969, from 1977 it has engine M 1433 that matches the frame in model and year but is not the original. It is an odd looking mag and I think it may be a Miller. The 3 pip Lucas pick up may fit, Draganfly list them under number 451321 but find out which mag you have first!
