Lad's,
Id just like confirmation on which is the correct headlight for my bike, the 1947 - 1948 parts book shows a DU42R. Am i correct in saying that this is the flat glassed lens variety and not the domed MU42?
Josh
Correct Headlight 1948 Ariel NG350
Re: Correct Headlight 1948 Ariel NG350
To add to the above,
Ive just been looking through the sales brochures located in the document library.
1946-1948 brochures clearly show flat lensed headlights, the dome lens appears in the 1949 brochure.
So going by the brochures, and the fact that the Ariel parts book states a DU42R, a flat lens must be correct.
Hi Josh,
I knew you were going to ask this question, so in anticipation, several years ago I did all the research and put it here https://draganfly.co.uk/product-categor ... onal-bits/
I did read that Roger and it had me just as confused.
Your write up on Drags states 45-48 had the MU42 (Domed), yet the 47 and 48 parts books state a DU42 (Flat)
And then we have the brochures showing flat from after the war until 48, then on domed
