Hi folks,
Could someone please tell me the thread type on the front fork top bolt (the one that screws into the fork tube) ? It seems to be 3/4" in diameter and 20 tpi not 26 tpi, but is it still BSC ?
Cheers,
Bevan
1950 Single Front fork top bolt thread
Re: 1950 Single Front fork top bolt thread
British cycle is 26 TPI and 20 TPI. Nev
Thsnks Nev.
Although I have a cyclethread tap and die set, it is all 26 tpi of course I want to make a fork draw bolt, so guess I'll need to buy a 3/4" 20 tpi bcy die.
OR buy a new fork top bolt and use the worst of your current ones to make the Puller. If you screw cut it on a lathe it's whitworth form. US cycle is 24 and 20 AN form . Nev
Or buy a puller upper tool from your favourite Ariel shoppe https://draganfly.co.uk/shop/85886/fork ... 2/#TOOL-32 usual declarations apply
