Nooooo Connection !
Looks like a car dealer that took in someone's Ariel
Possibly the frame is from a VB hence his 'VB' tag.
13950,- euro maybe, just maybe that first '1' is a typo, if not, one can always try .....
https://www.2dehands.be/v/motoren/motor ... 7-oldtimer
VB 4sale that looks very much like a NG
Re: VB 4sale that looks very much like a NG
Yes this is a whole lot of money… however the primary cases are right for 1937. If you look close to the 4th picture you will see a small hole between de the pushrod tubes. This might be a indication that the cases are also from a VB. In that case someone made a OHV from that ‘poor sidevalve’. But we can’t be sure, as we do not have the frame- and engine numbers!
Oil feed to rockers from return line. Cover over the timing chain is later type. Levers not right . Rear chain guard odd. TINY horn, Tank is probably W/NG. Wrong fuel tap. CP gearbox. Solid state regulator. Might run and ride well, but.... Nev
Users browsing this forum: Google [Bot] and 23 guests
