KH500 Camshaft Shims
admin
Post by admin »
For Les Carter:
Do the shims go on the camshaft shoulder inside the crankcase or between the chainwheel on the outside ?
(I got too keen on tidying up and deleted one post too many - which was Les's original. Sorry Les!)
Re: KH500 Camshaft Shims
They go behind the camshaft sprockets so within the timing case
Les Carter
Post by Les Carter »
Thanks Paul thought that was the case but needed to be sure.
Les Carter
1960 Arrow, 1951 KH500, 1935 VA, 1951 LE Velocette, 1957 BSA A10 with Monza Sidecar, 1954 BSA C11G, 1966 Norton ES2 Special, 1977 MZ TS250, 1999 Honda VFR 800, 1969 MG Midget.
