I’m thinking they are as rare as rocking horse droppings but just in case
Greg
DKXHA distributor wanted for Mk 1 Square four
- Paul_Linden
Re: DKXHA distributor wanted for Mk 1 Square four
Yes, original DKX4A distributors from a square four are few and far between, but do not despair as you can use one from an Austin 7 which are slightly more common. You will need to fettle the advance retard and change the gear at the bottom. Sometimes they have a little oiler fitted on the drive shaft.
Hello
Hello
You can use this one.
An adapter ring must be rotated.
best regards
https://www.rackkatrac.com/tete-de-dist ... ge-sev.htm
Hello
best regards
Users browsing this forum: Bing [Bot] and 22 guests
