New member with a 45 WNG build
Re: New member with a 45 WNG build
There are a set steel primaries on ebay,they are missing the clutch cover,which is not the same as normal Ariel one,it is for this fitment only.worth a look to see what you need.https://www.ebay.co.uk/itm/394054665615 ... 000%7C1500
Thank you, good to put a picture against what I should have!
It would be lovely to have it absolutely correct but for now that money will be spent on the parts that I don't have a suitable substitute for. I am sure I will regret not obtaining it now as I know that most of these items are likely to be scarce in numbers.
I hope to make some more progress this weekend and with a bit of luck would like to discover some parts at kempton!
Many thanks
Many thanks
Steel chaincases?
For members, see http://www.arielownersmcc.com/members_o ... incase.pdf
(The website - and Club membership - does have uses.... )
Amazing, thats a really good breakdown!
Thank you Simon!
Thank you Simon!
So I managed to get some items at Kempton which me and my 11 year old had fun rummaging through boxes of bits for.
A speedo drive for the front brake plate, a chronometric - sadly not quite correct but an 80mph one which will be fine for now, a correct headlamp shell and a lower tool box and a fuel cap which may or may not be correct but fits the tank. A little battle damaged by a previous owner but I like it.
Since then I have also acquired the speedo drive gear - lucky find on ebay as they don't seem to be available from Drags, a 4 position lucas headlamp switch, an old pattern front mudguard - looks identical to the ones pictured at Drags and seems decent quality too.
Also just recieved in the post a correct gear change lever as it was available and looks better than the modified one I currently have.
Had some help from the club gearbox parts service (thank you Geoff) and have rebuilt the gearbox less outer cover for now as awaiting a stud and some domed nuts
Just waiting for the engine shop to come back with what size the damage will clear at then I can order my piston and engine parts ready for assembly.
Here she is, I am reasonably happy with her! I know she is not totally correct and there's still a few bits to do. I have the wrong angle carb chamber so need to try and find one! Despite this she starts easily as long as you don't leave the fuel tap open! Once I have the correct one I will be able to take her out for a decent ride.
Thanks for all the assistance given by the site and members!
Doesn't look too shabby. You should get away with the 11 degree bowl but they are available new The float needle should improve with a bit of use but don't allow flooding as there's risk of fire. Mine went on the road in 1997. Always been a very easy starter and a non oil leaker and super reliable. The "Original " Gear ratios I eventually exchanged for the non trials type as the jump to Fourth gear was too widely spaced for comfortable road purposes. She's done quite a few miles. 2 rear tires. and a new chain and gearbox sprocket. Nev
She looks great
