Hi all
Just thought id do an upgrade on my 1952 Ariel square 4 electrics and replace the points with an accuspark ignition system.
I thought this would be straightforward enough, but when I removed the points baseplate and all the gubbins and replaced it with the new accuspark one, it immediately became apparent that on screwing it down that it rubbed against the advance / retard mechanism binding up the whole shaft. Anyone else had this problem when fitting the new baseplate?
I'm sure I have the right unit but wondered if any additional mods had to be made
Thanks
Mark
Any accuspark experts out there?
Re: Any accuspark experts out there?
Mark
I'm not an expert but from others?
'....open out the central hole in the plate to clear the advance/retard unit....drill/tap two 3mm holes to relocate the sensor unit to give distributor adjustment without fouling the oil tank....'
viewtopic.php?p=73295&hilit=accuspark#p73295
HTH
HTH
Mark, I got the Accuspark ignition and had exactly the same problem as you,if you look at Draganflys electronic ignition IGN-15 it has a metal spacer under the baseplate, there must be differences between the car and motorcycle distributors somewhere
Thanks for the prompt reply chaps - really helpful.
At least I now know its not just me - always more work than anticipated with these straight forward mods.
Thanks again
mark
Thanks again
mark
