Ariel, Riding, Breaking and Fixing Diary 2022 Retired!
Re: Ariel, Riding, Breaking and Fixing Diary 2022 Retired!
You need an oil with friction modifiers, BADLY or your valve springs are too strong. Fair bit of metal off there.. It's steel so a magnet would have helped. Other wise I'd clean out the crankshaft (Plug removal.) It's too cold to ride anyhow. Happy New Year.. Nev
- Steven.Carter
I've had no problems with my previous engines, hmm, could be spring's, I didnt check to be honest Nev, She's done 15,000 miles on this engine and I'll trust my magnet, I've a filter fitted so that might do some good, maybe a few more frequent oil changes.
. I did hear somewhere that some duff cam followers were about.
FERC went back together easiest its ever have, I normaly spend an hour or two faffing with it Head on Rocker box fitted OK too, and sarted without any rattles
- Steven.Carter
She lives again, that loud tappety noise has gone, front forks feel so much better.
I took her for a spin to the watercress line with my friend Andy and his recently rebuilt S8. So it was a leisurely ride not much faster then 45mph. No oil leaks, but riding home a bit faster the rocker box did leak a little bit.
So I thought I'd experiment, I drilled and tapped a hole in the rocker box inspection cap. I screwed in a carburettor adjustment screw with a pipe attached, might drop the pressure in the rocker box and keep the oil in, can only fail miserably
That's a lovely picture of Lady of Legend, a recreation on Churchward's Saint
class from the early days of the last century. Criticised in their day for
being unduly angular I still think they look elegant.
I bet she leaks more than Steve's FH!will_curry wrote: ↑Fri Dec 30, 2022 6:41 pm That's a lovely picture of Lady of Legend, a recreation on Churchward's Saint
She'll have hydrostatic lubrication with four feeds adjustable for flow from the footplate.
With a driver who knows what they are doing they can be remarkably frugal with oil.
It was with a similar engine a very young Will was told when asking about oil coming
out of a big end bearing 'If oil's coming out dirt and water aren't going in'.
- Karol Burger
I hope to drive more kilometers in 2023 than this year. I like to read about your trips for tea, to a friend's house or to the locomotives. I will have to try a little more to drive and work less.
ALL work and no PLAY they say, Karol. 2022 is just about over. 5 hours to go here. Happy new year everybody!! Nev
She's certainly a fine looking machine. We don't get many western locos up here, but I was lucky enough to spend a day firing 4270 last summer.will_curry wrote: ↑Fri Dec 30, 2022 7:49 pm She'll have hydrostatic lubrication with four feeds adjustable for flow from the footplate.
- Bob.Murphy
That looks like a very uncomplicated cab !
Used to haul coal trains around Wales it seems, almost never used for passenger owing to its limited water storage (a Pannier Tank).
as a 4-8-0 I'm guessing it wouldn't be used on branch lines with tight curves. Up here we have 62712 "Morayshire" - a 4-4-0 that could handle the curves in the Scottish Highlands.
Good to see it restored.
Users browsing this forum: Ahrefs [Bot], Paul_Linden and 21 guests
