1944 Model W/NG Parts List
Evening all
I've just joined up to see if the site could make use of a digital copy of the attached or is it a pretty common listing?
Thanks.
Mark.
Thanks.
Mark.
Re: 1944 Model W/NG Parts List
There's a lot of different W/NG parts lists, corresponding with the different contracts. If you're happy to scan it I'm sure the club will want to put it in the knowledgebase.
I would love to see that one as it is not currently available
They are extremely useful to settle issues about the correct items for the various models. Stops people (experts so called ) claiming such and such is WRONG for a W/NG. Some even had Matchless motors and the original offering was based on the 39 ISDT bikes complete with horrible ratio trials gearboxes longer forks and high ground clearance frame that makes them a bit wind sensitive if you're moving it along. Of My small collection it's easily the one that has done the most miles with me aboard. Worn out 2 rear tires, so it hasn't been a static exhibit. Nev
Yes please do get it scanned, thats as close to the year I am rebuilding!
Many thanks
Adam
Many thanks
Adam
Lovely, I think my mum will be bringing over at the weekend so I'll get it scanned and I'm guessing a PDF is the best format.
Mark - a PDF will do just fine...!
Many thanks
Many thanks
Here you go all,
Please have a check and let me know if it runs through ok, it also had an electrical diagram in side from another unknown source (Lucas Standard?), let me know if its applicable to your bikes and if you want i can repost with standalone pdf for that sheet (its one of the last scans in the attached currently)
Merry Christmas all
Merry Christmas all
- Attachments
- Ariel Motor Cycles Parts List Model W_NG 1944.pdf
- Ariel Motor Cycles Parts List Model W/NG issue 1944
- (4.93 MiB) Downloaded 48 times
Also noticed that another site i use for general motorcycle manuals/pdfs ( Carlsalter.com ) has a file in his full listings for (Ariel doesnt have its own grouping on his site) for a 1961 parts list for the Leader/Arrow
"Ariel 250 Leader & Arrow Illustrated Parts List Diagram Manual 1961"
full list link https://www.carlsalter.com/all-motorcycle-manuals.asp
Direct link if needed/allowed https://www.carlsalter.com/download.asp?p=139
