VH Piston 1956
Philmynd
VH Piston 1956
Post by Philmynd »
Good morning all,
Following the destruction of a valve seat...I have to rebore my cylinder and find a new piston.
My surprise: I have an 83.5 piston and I need to find an 84.
Normally a VH is in 81.8, can you give me an explanation!
Thanks
Re: VH Piston 1956
Post by will_curry »
I don't recognise the size: BSA Gold Star is 85mm and Vincent twin is 84mm.
Your piston looks to be very worn and the top ring at least is blowing by badly.
A rebore was about due anyway.
Philmynd
Re: VH Piston 1956
Post by Philmynd »
In your opinion: is an ARIEL piston or other?
Re: VH Piston 1956
Phil
It looks very much like an Ariel piston - could be +060 inches, which gets close to your size and would be the biggest standard oversize.
If you clean the top carefully you might find the oversize stamped on it.
Also, what letters and/or numbers are inside it?
Philmynd
Re: VH Piston 1956
Post by Philmynd »
Here is the top of the piston: dimension 83.4.
no indications inside....!
The pieces of the seat have damaged it well :(
Philmynd
Re: VH Piston 1956
Post by Philmynd »
do you have a plan for a piston like this in 84... Thanks
Re: VH Piston 1956
I don't think it is an original Ariel piston but it might be a replica of some kind. Of what kind I have no idea.
Re: VH Piston 1956
It's pretty thick but would have been OK at the original size. Not many pistons are 81.9. IF the pin size is standard for Ariel, I'd say it's an after market part. Nev
Philmynd
Re: VH Piston 1956
Post by Philmynd »
Comme suite à ma demande chez DraganFly :
Good morning Phil
Customer number 1****6
I am sorry, in this instance, we can not help you, i suggest you contact the owners club for advice?
Kind regards,
Bryan
J'ai fait une demande à Allan Simpson.
Re: VH Piston 1956
Looking through my stuff I've found one just like it It has a mark where a valve has touched the surface as there's no valve cutout machined.. After market .Maybe Italian? Same large machined relief under the Domed part. Nev
