"Mainshaft, gear side", 1954 - 58, part no: 1150-35. - New or used in good condition.
Also lh thread nuts.
- As on photo:
Petri Järvinen
WTB: - VH500 1954 Mainshaft RH.
- Attachments
- 1150-35U-600x397.jpg (85.5 KiB) Viewed 806 times
2 X Ariel VH500 1954, Indian Scout 101 750cc 1929.
- john.nash
Re: WTB: - VH500 1954 Mainshaft RH.
Is this the same?
Hiw can I tell as there are no numbers on it
John Nash
AOMCC No.4119
AOMCC No.4119
No John, it isn't the same. Look at the large end of the taper which goes into the flywheel. Yours has a step there which makes it the weaker type. The one wanted has no step which is the stronger Red Hunter type.
There are 3 versions of this shaft, one of them has the holes in a different position, check carefully before use!
- Thanks for the clarifications, the axle is still in search...
PJ
PJ
- Still looking for mainshaft axle and nut; 9/16" 20 TPI lh .
Hello.
- Thank you all for your interest, the parts have been found in Denmark.
