Hello,
Anybody could help me with the specs about the VB600 1951 piston?
I need to know it´s standar dimensions.
Diameter, high, and everything I could have.
It´s because when I bought this motorcycle, the engine was under a restoration process, and it has a new piston, but I´m not sure if it´s the correct one.
Pictures could be great to!
Best regards,
Luiz
VB600 piston specs
Re: VB600 piston specs
All the dimensions and all the part numbers are on this page, look for "Pistons and Rings" https://draganfly.co.uk/ariel-technical-articles/
You can then search for 11327, which is the part number for a VB piston
Users browsing this forum: Ahrefs [Bot], Karol Burger and 1 guest
