Bike stands
Bike stands
Hello
I am new to Ariel and recently bought 2 Arrows one was a mistake bought in several boxes and sold as a Sports Arrow but soon found it had a Leader engine and frame and other pats a mix of arrow and leader. I managed to get some refund and have now bought a Arrow sports all genuine numbers and V5 but in need of a strip and repaint. It’s a 1961 and appears to have had little use and runs. The main reason for the post is I would like to buy a bike stand to make life easier than working on my knees, as it does not have a frame like most bikes can anyone recommend a stand/lift that works with these bikes?
stu
stu
Re: Bike stands
Use a hydraulic bench also available with a hand cranked platform. I wouldn't be without mine although I have done plenty of repairs 'in the field' and most recently a bus shelter without one!
Re: Bike stands
Is this the type you roll the bike on and it just lifts it on the wheels. So if it is on the centre stand which is part of the engine i then take of the rear, wheel, mudguard and swinging arm. Does that sound right?
Re: Bike stands
hi there is lots of types of lifts if you have got room for a full lift that the back end of the lift comes off so you can remove the wheel etc, or you can get one that lifts it under the engine have a good look on Ebay there lots of them on it and different types and it will help you find the one you need
Re: Bike stands
I guess some of the table lifts don't work too well with a rear stand?
Re: Bike stands
hi when i have got one on the table lift with a rear stand and i need to remove the front or rear wheel i use a little lift under the frame and engine that i put under it when the bike is on the table lift , or i use it on the floor if i need to remove a wheel ect
Re: Bike stands
I'm with Johnny on this one, I use a Sealey 365 'X' lift table, (as it 'expands' less when lowering) and a small scissors lift for additional support when removing wheels / stands. Not the cheapest option but more versatile.
Shop around, the price variation is staggering.
Re: Bike stands
hi like the ones that mick is using i got a new little scissors lift off Ebay for £29.99 with free post and packing to my door last year so have a good look around like Mick says
Re: Bike stands
hi stu ;
i have one of these switzer stands , link below , my leader is sat on it at present .
https://www.ebay.co.uk/itm/384954581577 ... SwGXxirGO7
did a couple of mods to it by adding a different front wheel chock with tie downs that i bolted onto the table at front , the original wheel clamp isnt up to much really .
i also added a couple of extra ring bolts along the sides of the ramp to use for tie down points .
i would also say put the ramp on top of a piece of old carpet so it doesnt move on a concrete floor when you push bike on and put it on main stand etc , all the mods etc were a tip from my mate mike [foxy] who also has a leader and other ariels .
i bought a spare seal kit for the ram too but cant find the link to the seller right now .
some of these types of ramps use same ram .
https://www.ebay.co.uk/itm/123761467442 ... BMtor7_Mpg
regards
ian
regards
ian
Re: Bike stands
C J Autos is always a good place to look.
Hydraulic lift:
https://cjautosheywood.co.uk/product/hy ... ift-mb03c/
Modified with lifting eyes at each corner for tie down straps. Tie down straps always slide better through stainless eyes.
https://www.westfieldfasteners.co.uk/Ma ... sQEALw_wcB
I use one of these if a bike comes in without a centre stand:
https://cjautosheywood.co.uk/product/mo ... ock-mb111/
Hydraulic lift:
Users browsing this forum: Majestic-12 [Bot] and 13 guests
