VH 1956 44-tooth primary chain sprocket
Wanted:
44-tooth primary chain sprocket for VH 1956. France, AcknowledgmentsRe: VH 1956 44-tooth primary chain sprocket
Hi Members,
I found the 3380-36 sprocket at Draganfly, but can you tell me where to find the center of this sprocket: 3380-05
Thanks
Thanks
hi you may get one from Greff brown at the AOMCC gearbox spares or try john budgen he has a lot of spares
Phil:
For the Drags sprocket you would usually re-use the centre from your old sprocket (or a spare old sprocket).
It is really marked, the surface treatment has disappeared in places
Remanufacturing seems obligatory.
Philippe
Philippe
It looks good to me. If it is the centre where the bearings run that is of concern. It is really hard and not likely to wear as the bearing only operates when the clutch is operated. Any vertical movement in the bearing is usually cured by a new set of rollers.
Trouvé en Grece !!
Toutes les pièces sont arrivées, remontage et essais
hi when i rebuilt my gearbox and clutch i just fitted new rollers in the basket that i got from the clubs gearbox spares i have never needed to change the basket
Hello.
I got this NEW OLD STOCK for sale.
If interest you are welcome to send a PM to:
<ariel.andersen@godmail.dk>
Jorgen
Jorgen
