Hi all, I have a late '40s rigid frame bike with a BA gearbox. The primary chain adjuster snapped and I have a new replacement. Only as I went to fit it did I realise that there is no room at the side of the pin it locates over, to slide the adjuster on whilst everything is together. Do I assume I have to remove the r/h side engine plate to get the new adjuster on?
Thanks, Tony.
BA gearbox adjuster replacement.
Re: BA gearbox adjuster replacement.
yes, or perhaps take of the prim. chain and try to move the box backwards, but maybe you also have to remove the clutch basket.
that or maybe in combination of some wiggling the -loose- engine plate(s) etc.etc.
Just loosen the one plate more at the top. Don't take any studs out. Once the eye is on the pin, the rest slips in place. Nev
Thanks for the advice guys. I'll let you know how I get on.
hi i took out the bottom pivot bolt spacers out and top bolt and the clutch side engine - gearbox plate and moved over the box and put the the new ajuster
Great, thanks.JohnnyBeckett wrote: ↑Mon Jul 18, 2022 10:55 am hi i took out the bottom pivot bolt spacers out and top bolt and the clutch side engine - gearbox plate and moved over the box and put the the new ajuster
I'm getting some new clutch bits from the club, so will tackle the whole thing in one go.
Cheers.
Users browsing this forum: Google [Bot] and 24 guests
