1929/30 girder fork blades
Looking for set of girder fork blades for 1929/30 Black Ariel in serviceable or repairable condition if anyone has any leads. Many thanks Richard
Re: 1929/30 girder fork blades
there is a 'wanted' section for this, please. thank you.
Have you got them, but they are beyond repair?richard.harvey wrote: ↑Thu Jun 09, 2022 5:55 am Looking for set of girder fork blades for 1929/30 Black Ariel in serviceable or repairable condition if anyone has any leads. Many thanks Richard
- rein.heerkens
Sent you a pm
Apologies Vincent for not using "Wanted" section. Have not been on Forum for a while. But just to finish the thread - Simon, I do have the original set and they looked OK; however, close inspection showed cross tube between friction plates bent seizing shaft, one of the friction plates also bent fairly badly and one of the down tubes has been partially replaced using silver solder!! My advice was that whereas it might be possible to repair, it would be a massive job and it might be cheaper and safer to source another. Richard
Did you talk to Jake Robbins?
Moved!!!
(Vincent - 'green names' also have the power.... )
Administrator
webmaster@arielownersmcc.com
Maybe we should put Jake Robbins in 'Suppliers'
However, several other forum references including:
viewtopic.php?f=7&t=11911&p=83466&hilit=jake#p83466
Administrator
Users browsing this forum: Bing [Bot] and 31 guests
