Hi Guys wanted Square 4 Mk11 Crankshaft Sprocket Duplex 1944-57 Thanks Keith
Wanted Square 4 Mk11 Crankshaft sprocket
Re: Wanted Square 4 Mk11 Crankshaft sprocket
I do have a spare one of these but it is missing one tooth. The corresponding tooth on the other line of teeth is present, as are all other teeth so I would think it would work perfectly well. Presumably, some hooligan broke the tooth off by using a tyre lever or similar to remove the sprocket. Give me a ring - number inside front cover of Cheval - if it is of any use to you.
Hi Paul trust that you are keeping well thanks for replying. Yes I have the same problem one broken tooth. Being an ex bloody engineer I can’t bring myself round to installing back together with a broken tooth. Can you imagine the objections the brain voices would inflict on me? Fortunately contacting Bruce, had some 4 keyway tooth sprockets. Takes a long time to get items from Brucy, he does not like using bank transfers. Took me a day to find my cheque book that I had not used for years. Hopefully should see it next week, waiting for it to arrive has allowed me to clean out the workshop that’s looking spotless again.
Keith
Keith
The art of getting a quick reply from Bruce is knowing when he is and is not away on rallies.
Users browsing this forum: chris.shearwood and 16 guests
