Is there an oil seal behind the crankshaft shock absorber on a 52 HV500?
I cannot see one in the Drags drawings.
If not, what prevents oil seeping into the primary chain case?
Many thanks,
Dennis
1955 VH500 alloy head
- dave.owen
Re: Is there an oil seal behind the crankshaft shock absorber on a 52 HV500?
No oil seal
Fit of spacer (behind sprocket) into crankcase is usually enough.
Thanks both. I queried it because some Ariels of that vintage have an oil seal in that location. I have the sprocket spacer and it is a close fit so hopefully minimal leakage.
Dennis
Dennis
There's usually NO problem there with oil seeping. Even if a bit did it would stay in the chaincase. Nev
Users browsing this forum: tony.barnett and 1 guest
