HI Tony--still looking for the front brake actuator (alloy part that pushes the shoes) and actuator lever for W/NG--have the shoes now.
If you know anybody that may have these please let me know.
thanks
Tom Colbourne
W/NG parts wanted 1943
Re: W/NG parts wanted 1943
Hi All--I've been able to find the following so don't need them now:
Passenger footrests
primary chaincases (steel) and clutch dome
rear brake rod
Still looking for lower chain guard and speedo mounting bracket
And now also looking for front brake parts-cam bearing, cam actuator, etc.--any front brake parts except the brake plate and shoes (and springs) which i already have
Passenger footrests
rear brake rod
Sorry Tom, I meant to get back to you. I never did find the second rear footrest. My garage is such a mess, it's in there somewhere.........
Have you sourced a pair from someone else then?
Just an FYI--got everything now except the Lower Chain Guard and speedo mounting brackets.
Those bits are quite easy to make if you can't find them...
