Nh350
- keith.mettam
Re: Nh350
Hi Pete,
Have you tried 'flashing' it for correct polarity first ? When 'motored' on a battery the armature should spin in the same direction as it spins when fitted on the motorcycle (anti-clockwise looking at the brush/commutator end on your NH). If it doesn't and you have the correct (earth) polarity lead connected to the dynamo's body when trying to 'motor' it, try swapping the field coil wires over in the dynamo which, hopefully, will solve the problem.
All the best with it,
Keith.
Keith.
Re: Nh350
Update on dynamo hands up I had it completely wrong all wiring was correct my fault was try to power it up as a motor completely wrong ,as a last resort I cleaned the brushes which are brand new heypresto it charges ,just goes to show check the simple things first
Re: Nh350
Glad to hear dynamo is now working OK, I had borrowed a dynamo from a friend in case there were still problems, and spent the morning cleaning and checking it out, spinning it with a drill gave 7-8 volts, so at least I can tell him it works!
- keith.mettam
Re: Nh350
Pleased you figured it out Peter, another hurdle over !
All the very best,
Keith.
All the very best,
Keith.
Re: Nh350
Cable on right at points end is tight wire advance
