Hymn to the 1928 Model C
Re: Hymn to the 1928 Model C
On to fin repairing, always (well, to me) a bit of a nerving thing...
Made a set up with my pottery kiln and a electric stove to keep the heat in the cylinder while welding.
(electric stove I once liberated from the scientology church rubbish bin, but that's another story )
cranked the kiln to 280 C. MIG welder on 6 with low wire speed.
No pics of the actual welding.... gloves to thick to push any buttons
Happy with the result after some grinding with the Dremel.
few nuts and a bit of tin sheet to get the position right.
(yes I did burn out the nyloc before work..)
post Dremel....
post Dremel....
Looks a neat repair.
- Karol Burger
I wonder if you will find a repair spot after the black paint Nice work.
If I make it to the Dutch this year I will buy you a pint and you can tell me the story of liberating a kiln from the scientology church rubbish bin
- Karol Burger
I would also like to hear that story
Vincent, can I join in with a pint to listen to the nice kiln story?
I will get a parcel ready for you with a few barrels where fins are missing. Once you now know how to do it!!!
Shall I let the tension rise and wait till the German rally or ....?
If I wait I'll have those beers up front, once those have settled in the tale only gets wilder
Or... It could be just another douchebagstory....
Klaus, funny thing with this iron welding..
If the parts are mine it goes o.k.
If the parts are not mine I'll fuck up and crack them
Gathered enough courage to tackle the cylinderhead now.
Fixed the two broken bits on the cylinderhead .
ready for the next step.
- cmfalco
Your repairs look great.
- Bob.Murphy
I'm curious about this - are you MIG-welding mild steel repair pieces onto cast iron (or have I got it wrong)??
From what I have read and seen on 'You-Tube', it would be best to braze cast iron pieces onto cast iron because of the different coefficients of expansion between cast and mild steel (and MIG wire).
The repair does look good though.
Users browsing this forum: Ahrefs [Bot] and 9 guests
