W/NG parts wanted 1943
Also looking for:
Lower toolbox (have the upper one-but it's mounted as a lower)
rider and passeger footrests
rear mudguard stays
Speedometer (any condition-to fit W/NG)
Primary Chain cases and clutch dome ( have the primary cases -but in rough shape--no clutch dome)
Rear brake rod
rear mudguard stays
Rear brake rod
Re: W/NG parts wanted 1943
Hello Tom, you have a PM.
thanks Vincent-i checked.
Here's my new "wish list" for the W/NG--i've found some parts already.
Lower toolbox
passenger footrests
Primary chain cases and clutch dome
Rear brake Rod
Timing Gear Inner Case
Speedo drive small gear running in front hub
thanks for the feedback folks
Lower toolbox
passenger footrests
Rear brake Rod
Hi all--more parts:
Front brake innards including shoes--i have the brake plate and speedo drive (except the little gear).
Cheers to all and happy USA thanksgiving.
I have W/NG passenger footrests on my bike, happy to get rid of them and replace with rubber. However, they were chromed some years ago, though very worn, probably paint ok if you give them a good blast. I can send pics if that helps.
Great--i have the front ones--rears are a bit harder to get. don't need pics but maybe private message re price etc.?
Hello Tom,
Small speedo gear just arrived from Johan, I will put it in the parcel with the timingcase and let you know the postage.
thanks so much Vincent-just got your message that the gear is on the way! (and the timing case-thanks so much for that too). And best of season to you and yours.
Hi All--here's my new wish list for xmas! For 1943 W/NG:
Lower toolbox
passenger footrests
Rear brake Rod
Lower chain guard
Speedo mounting brackets (i see there's a pattern on the site for someone who's made a set)
Tom Colbourne
Lower toolbox
passenger footrests
Rear brake Rod
Lower chain guard
Tom Colbourne
I've sent you a pm Tom.
