w/ng speedo wanted
tcolbourne
w/ng speedo wanted
Post by tcolbourne »
Looking for a speedo for w/ng--used or rebuilt also looking for the gear that fits on the drive end of the speedo drive that connects with hub gear.
Re: w/ng speedo wanted
This dealer maybe has those gears: The Matchless Shop, Johan Geertshuis 0031 493599318 or geertshuis@zonnet.nl
There's a few different ones. Have you an original for reference? They need regular attention to keep grease on and set them up right. I've worn one set out and didn't find any of that stuff easy to get. Nev
14 teeth it has :
And it has this kind of groove to keep the split pin out of the works.
(ofcourse not so mangeld as this one....)
tcolbourne
Thanks so much for the info Vincent. I will contact "the matchless shop". I don't have the original--I have a 1943 w/ng so I think it's 14 tooth? With a good 3D photo and the exact dimensions I can get one made out of brass or 3D printed.
tcolbourne
Part no 5246-38 - my drive gear in the hub is in good shape--thanks for any feedback from the club folks--i'm sure i'm not the first w/ng restorer to encounter this issue.
follow this link : https://www.cornucopia-enterprises.de/spares-ariel.html
Do not take the notice 'just ask' litterally !
Ariel
Speedo , Brake Drum Gear and
Speedo Gearbox Drive Pinion
Replica
fits Models WNG, NG and Others
( 1 ) Hub Gear 43 Teeth Part No. P52233 70,- euro
( 2 ) Speedo Gearbox Drive Pinion 14 Teeth Part No. P/M 50215 52,- euro
