Having nearly finished the overhaul of my 1946/47 350 Red Hunter all I need is the 1/4" rocker oil feed pipe from the oil pump casing up to the two rocker covers. I ordered on with Draganfly in August 2020 and they still haven't had any stock in, neither has the very helpful John Budgen.
If you have a spare one, new or secondhand, I would be eternally grateful if you would sell it to me! Thnak you.
'46/47 350RH Rocker Oil Feed Pipe Wanted
- robjameson
Re: '46/47 350RH Rocker Oil Feed Pipe Wanted
If you go to your local chandlers they will have imperial copper pipe and fittings and you should be able to make one up yourself.
Rob Jameson
AOMCC Member Number 4068
1957 Ariel VH
1954 Ariel KH
AOMCC Twin Spares Organiser
1957 Ariel VH
1954 Ariel KH
Hi,
I have a 1950 NH with same pipe setup--i had the fittings for the rockers and the fitting on the timing side casing from the oil pump--i made up my own pipe using 1/4 brass tubing and soldered it together to the fittings--works just fine--i painted it silver afterwards to match the covers.
