Barrels
PaulWoolley
Barrels
Post by PaulWoolley »
Can someone enlighten me please, are the pair of barrels the same for the Leader and the Arrow or do they differ
Paul
grahamhibbs
Re: Barrels
Post by grahamhibbs »
They are the same and interchangeable.
Graham
West Sussex
1942 Ariel w'ng
1928 Ariel Model B
1960 Ariel Arrow
1960 Ariel Leader
1961 Ariel leader cafe racer (under construction)
ian williams
Re: Barrels
Post by ian williams »
hi paul ;
they are all interchangeable but there are also 200cc barrels which have a 48mm bore as opposed to the 54mm for the 250cc .
plenty of second hand barrels about so dont worry if you need any .
ead i think , slant plug early lower compression , then 10-1 straight plug type and also some which were used for 200cc engines
regards ian
PaulWoolley
Re: Barrels
Hi Ian
Thanks for the info, luckily I have just bought what appears to be a matching pair of barrels off of e bay and both bores measure 54mm (phew!)
Paul
