1929 LB250
1929 LB250
Hi, I know some of you thought it should go back in a skip, but I didn't & I bought it ! I was wondering if the engine and gearbox numbers match & what to do about the unreadable frame number if I Retube and repair it??? I remember a BSA in my ownership being x-rayed or something similar in the distant past to check if it was the original number. Can something like this be done these days??
Engine no is :- L1539 Gearbox is :- RPD3825 I know it will be loads of work but think its worth while.Re: 1929 LB250
Sorry photos didn't download!
Re: 1929 LB250
If any one can Jim, then you can, I've seen the proof mate, good luck with it and well done for saving it.
Re: 1929 LB250
Look closely at the gearbox number. It should be RPD3823
Re: 1929 LB250
Wow! good luck and keep us posted!
a while ago I've seen a Black Ariel front fork spring in someone's stash.
If you need one I can ask , maybe send me some dimensions so I can check.
Re: 1929 LB250
Thanks Paul, yes I think you are correct
Re: 1929 LB250
And yes please Vincent the front spring is past it, I did have a spare but a guy here in Scotland needed it to get back on the road.
- Paul_Linden
Re: 1929 LB250
Good luck and remember to keep the forum updated with news pictures, and progress on the rebuild.
Re: 1929 LB250
The world's undisputed expert on Colts is Roland Robinson so you might want to speak with him.
Moto Guzzi V7 Racer Mk2 (ABS)
AOMCC Member 3400
AOMCC Member 3400
Re: 1929 LB250
hi i wouldn't like to risk my life on a frame like that unless you make a new frame then you are not saving a old ariel
Users browsing this forum: Ahrefs [Bot] and 22 guests
