W/ng rear stay
General talk about the W/NG
RTichard Woolnough
W/ng rear stay
Post by RTichard Woolnough »
I have finally bitten the bullet and following a long discussion with 'Trevor' at Dragens den believe we identified the correct stay and lifting handle for the '42 W/ng,[ which I have purchased,] I have a rear guard and a hinged part which now mate, there are a couple of what I feel are extraneous brackets attached to the original front part which makes me think it could perhaps be from another era, these will remove easily, what I could do with a picture of the tail end showing the original mounting of the guard and the stays, if anyone could post one it would be much appreciated, Thanks
Kind regards
Re: W/ng rear stay
I have hundreds. The rack is not original but the mudguard and stays are correct...
RTichard Woolnough
Re: W/ng rear stay
thanks Simon, is that a hinged guard?
kind regards
RTichard Woolnough
Re: W/ng rear stay
ah, I have enlarged it now and can see it is and also one of the lugs I mentioned I see is used.
kind regards
Re: W/ng rear stay
RTichard Woolnough wrote:thanks Simon, is that a hinged guard?
kind regards
Absolutely, and a brilliant idea it is too:
alan.moore
Re: W/ng rear stay
Post by alan.moore »
And here's one from my WNG showing the front bracket that attaches to the engine plate:
Alan
Re: W/ng rear stay
That double cranked bend is not as any original I've seen. I think your guard is a bit over to the chain side. Nev
RTichard Woolnough
Re: W/ng rear stay
That's an interesting picture of the lifting handle mounting, the one I have purchased has the guard bracket welded to it but the pic seems to show a separate part attached by the bracket which is on the guard, I may have to sort this out a tad by removing this piece and drilling a locating hole, at the moment the guard will have to slide between this and the lifting handle.
kind regards
alan.moore
Re: W/ng rear stay
nevhunter wrote:That double cranked bend is not as any original I've seen. I think your guard is a bit over to the chain side. Nev
Nev
If it my photos of the front bracket you refer I think its an optical illusion. The bracket is just a plain 90 degree bend. The centre rib of the mudguard is inline with the centreline of the frame so all's good :D
alan.moore
Re: W/ng rear stay
RTichard Woolnough wrote:That's an interesting picture of the lifting handle mounting, the one I have purchased has the guard bracket welded to it but the pic seems to show a separate part attached by the bracket which is on the guard, I may have to sort this out a tad by removing this piece and drilling a locating hole, at the moment the guard will have to slide between this and the lifting handle.
kind regards
Can you post a photo of what you have?
Have you had a look on Drags site at the mudguard section. They have good photos of the W/NG mudguard (with the bracket that the lifting handle attaches to riveted to the mudguard as original) and the lifting handle/mudguard stay assembly. The Drags link is below:
https://draganfly.co.uk/product-categor ... r-to-1951/
Alan
Users browsing this forum: No registered users and 13 guests
