HD wobble
HD wobble
First comment : If their engineers were as good as their lawyers then their bikes would be great.
https://www.youtube.com/watch?v=Gmw6QppXnEY
- adrie.degraaff
Re: HD wobble
The Harley is to HEAVY .......for the rear tire.
Re: HD wobble
I always thought the Harley Weave was something favored by tonsorially challenged owners
Re: HD wobble
Play fair - the film is from 2006
The newer ones are supposed to handle a lot better (although something weighing over 700 lbs is always going to be a handful!)
Full marks to the tester though. He kept going back for more!
- Bob.Murphy
Re: HD wobble
Call that a wobble . . You should have seen my Square cornering at speed when loaded with camping gear !!
- chris.vredenbregt
Re: HD wobble
A friend of mine crashed one of these monsters a 2014 model, at 110 km/ h in a straight way he was Lucky to be trown of before it started to role sideways
Re: HD wobble
I think I have mentioned this before but back in the fifties "tank slappers" were fairly commonplace. I don't know what caused them - speed was involved and as I remember, not necessarily cornering. It happened with girders and teles. It was a common subject for discussion. The perceived wisdom at the time was to try to accelerate through, but easier said than done.
I can remember it happening three times at least to me. Surely some other of you old fogies will remember it.
I had a fairly long break from riding from 1956 until the late 60s and since I started again on just the same models of bike
I have never heard of it or experienced it at all.
John Mitchell
Re: HD wobble
25mph and below my BM (R100RT) will 'slap' the bars violently if you try riding with 'fingertip control' (I've had it over 25 years/200k miles and I think it's always done it notwithstanding anything I've done that might make it more stable - rebuilt/changed forks, new rear dampers, umpteen new tyres).
Doesn't do it at speed fortunately although you can make it a bit unfriendly by putting load and loads out on the back....
Re: HD wobble
About your BM, try giving it a bit more then standard pressure in the tires.
Re: HD wobble
Quite often run with 36/42 (psi - f/r) Vincent!Vincent.vanGinneke wrote:About your BM, try giving it a bit more then standard pressure in the tires.
Users browsing this forum: Bing [Bot] and 4 guests
