Battery Voltage Monitor
General electrical problems
JimKing
Re: Battery Voltage Monitor. Another Chinese Cracker?
Post by JimKing »
Another ebay offering for £8. Useful for an easy fit check. Complete with on-off switch and long cable to tuck under tank and connect directly to the battery. Even has a fitted in-line fuse.
JimKing
Post by JimKing »
Post by JohnnyBeckett »
HI Jim that is a good monitor and a good price to, do you know the EBAY number
JimKing
Post by JimKing »
HI Jim Thank you for the link on E BAY i have ordered one for my 54 NH hope to get it in 3 to 4 weeks it will give something to do over christmas fitting it :D take care
chris.vredenbregt
Post by chris.vredenbregt »
Hi Jim how can it work on 6 volt as it says 12-24 volts I suppose that the switch Light needs 12 volt or am I missing something?
HI if you look at the photo that jim as posted of is Ariel the volt meter is showing 6.4 volts i was thinking the same as you but seeing it on jim's bike its ok, that's why i have order one :D
chris.vredenbregt
Its not impossible that it is a led that adjust itself to a lower voltage?
JimKing
Post by JimKing »
The description says 6 to 30 volts. I have checked on my variable voltage supply and it works down to 5.0 volts then cuts-off.
allan.walker
Post by allan.walker »
JimKing wrote:Hi, Try this link.
https://www.ebay.co.uk/itm/12-24V-LED-I ... 2749.l2649
Jim.
Unfortunately, now shown as no longer available. Probably more from other sellers, though.
