Hello
Search a front brake plate for Ariel WNG in good condition. Best regards
Wanted WNG Brake Plate
26'C, 27'C,28'C,31'MF, 38' RH, 43' W/NG
- rein.heerkens
Re: Wanted WNG Brake Plate
I think I have one, will have a look tomorrow.
When you get one set it up on a straight axle between good nuts and see how true it runs. IF there's any wobble correct it. The speedo drive and the gears are expensive and hard to find so the ones in the hub must mesh as well as can be achieved. I'd recommend you use nonfling grease and apply it fairly regularly as you can't put much on as it gets on the brakes if you apply too much. I wrecked a set of gears as I neglected an often used bike at one stage. Check also your speedo cable and the speedo itself are free to rotate easily. Nev
