The Beast lives
Re: The Beast lives
HI IF it was me i would be out riding it and do the cleaning and tidying up as i go now it is running enjoy it
Re: The Beast lives
Just filling the forms in to change it to historic vehicle, it does not need mot and has insurance
so good to go soon, I am one of those that never see a cop but let me ride a un-taxed
bike 10 yards and one will be on my tail.
Re: The Beast lives
HI sounds like the luck i would have yo do not see them all day but as soon as i go out their they are and because its a old bike they follow you to see if you are all good
Re: The Beast lives
Seems to be running ok, battery charging lights work,
needs a clutch cable and a fuel filter as there's a bit
of muck coming out of the tank and the puddle under
the silencer is water, does a steady drip drip when ticking
over, just like my old Morini had to drill a hole in the bottom
of the silencer on that to stop it rotting them.
https://www.youtube.com/watch?v=LMsE0YN2nnU
- Eero.Korhonen
Re: The Beast lives
Nice tick over and great patina!
Br, Eero
Br, Eero
Re: The Beast lives
hi if you use led light bulbs the the amp meter will hardly move to the minuses on tick over and the lights are a lot brighter
Re: The Beast lives
Yep I agree, I have been thinking of going led, the headlight bulb holder could also do with replacement.
Re: The Beast lives
A big part of the noise on my NG seems to come from excessive end float on the rockers
any idea how much float there should be and are springs or spacers/shims used?
Re: The Beast lives
No shims or springs, just a fixed spacer washer on the W/NGs.. Most noise in Ariel singles comes from the cam followers being an "ordinary" (read worn) fit on the shaft they pivot on. There's not much end thrust on the rockers as the push rods are very close to vertical. ..Nev
Note a change here. The end float is determined by the dimensions of the shaft which pulls up against the pushrod side of the rocker box including a steel washer about 1/8th inch " thick. The rocker is trapped between the washer and the larger diameter of the non oil feed end. I never recommend thin shims on a situation such as this. Better to accept the extra play which is unlikely to cause any issues. It's well lubricated and usually doesn't change in end float. Not so with the earlier greased ones. Nev
Users browsing this forum: Ahrefs [Bot] and 18 guests
