Making the 650 HunterBird
Well, we are all trapped, so there's no excuse for not visiting the shed and playing with the next Victim.
I picked up a late 50's Ariel rolling Chassis just after Xmas and its been sat on the bench for a month or three waiting for the weather to warm up. The plan is to put a Triumph 9 stud pre unit dynamo motor and gearbox in that's under the bench from a Triton I had. I took it out of the Norton frame to make the bike back into a Norton a coupe of years ago.
Not one for originality. Some of you may have seen my VNH V twin Ariel last year in Cheval, I though it would make a nice sort of special. Sorry its only 50% Ariel but you have to use what you have and I have a lot of bits to use up.
I started a couple of weeks ago and if anybody is interested in progress I will post reports as it comes along
Tony Harris
Tony Harris
Re: Making the 650 HunterBird
keep us posted i like to see how you get on with it the triumph engine will make a good bike and reliable and easy to get parts i done a sq4 with a harley engine but now i was thinking of doing one like you are with a triumph engine to make a fast runaround
Yes, keep them coming !
- Steven.Carter
Me too I'd love to see how you get on
I'm struggling to post pictures at the moment to go with the story so will try again tomorrow.
Tony
Tony
Turns the right way up when I click on it and is looking good. Bob
1958 Huntmaster
1957 VH 500
1960 FB Cruiser 84
1957 VH 500
1960 FB Cruiser 84
So it does Bob. I will give more details tomorrow.
Tony
Tony
- Eero.Korhonen
That is looking good start!
Br, Eero
Br, Eero
As you can see the wheels are not the original ones. It came with the FWH Ariel wheels. They had alloy rims and new tyres. However, the tyres we quite old and as most people know, the original front brake was not the finest and with the Triumph 650 engine I need to stop.
I spotted an ebay a late 2018 Enfield EFI 500 front wheel complete with disc, spindle and speedo drive. It also had a new Avon Roadrider tyre, all for £80.
To go with this I ordered a new master cylinder, calliper and hose from India delivered free for £69. This is what you now see in the picture.
I striped the forks out and found new legs, bushes and seals. While the forks were out I machined the inner part of the steel bracket on the drive side leg square to the leg and spindle. This was to make sure the calliper mount I made bolted parallel. The bracket is mounted in three places including clamped to the wheel spindle. I has a piece of HE30 in stock and this has worked out great as hopefully the picture shows.
Unfortunately the wheel is green, I can live with this for the time being.
HI Tonyh i like the disc brake with out changing the forks you have mad a good job i must have a look at later bike wheels i normally change the forks to use a discs brakes i did not think about the later Enfields because all the old Enfields i have got are drum brakes keep up the good work
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Semrush [Bot] and 0 guests
