Upper and lower chain guard
LuisPaz
Post by LuisPaz »
May be wrong pic fron Draganfly but this is the chainguard for sell in your web. The upper seems ok but the lower? That vertical plate is correct for WNG?
Luis, from Argentina
1944 Ariel WNG
alan.moore
Re: Upper and lower chain guard
Post by alan.moore »
Luis
Top guard looks OK but original bottom does not have the vertical plate. Lower Part number WNG 5722-36 same as the pre war civilian singles. Dead easy to make yourself.
see this post http://forum.arielownersmcc.com/viewt ... chainguard
Here is the drawing I made based on an original guard (dims in mm) (The rear bracket in drawing is for sprung frame, for rigid bracket it is located on top of the guard)
I just made the brackets and attached them so that the centreline of guard was inline with the chain.
Hope this helps
Alan
LuisPaz
Post by LuisPaz »
Alan, you are the best! Thank you very much for your help!
With these data I can continue with the installation of the chain guards
1944 Ariel WNG
Users browsing this forum: No registered users and 25 guests
